Menzerna Power Gloss and a PC
Bioman
I have some deep scratches that IP did not get out. I was wondering how effective Power Gloss would be when using it with a PC? Has anyone tried it and if so, what are you're results/experiences? Thanks.
Btw, does anyone know where I could get a smaller version of the 32oz Power Gloss CMA sells. I think its too big for me.
If you can feel the scratch with you nail you will not be able to remove it completly only make it less visible. My advice would be to either fix the scratch yourself or have it professionally done and then buff the are out to blend it in. As for using Power Gloss with the PC yes it can be done I've done it with good results , I highly recommend using a wool pad with Power Gloss it gives the extra bit needed when using a compound with the PC.
I would try using a 4 inch cutting pad. That might also help, however you might have haze. Just use IP, to finish it down after PG.
