ZaneO said:On a pretty heavily oxidized car, do you recommend using the Menzerna or the AIO first?
What is the most effective way of applying the AIO?
Thanks.
I'm assuming you're referring to the 1Z paint polish. I actually used this on a 99 Sentra that had major oxidation and scratches. I applied two coats of 1Z in one day let it sit overnight then applied AIO the next day. I applied both products by hand. This was my first time using AIO and I did one section at a time. I used a terry applicator pad, sprayed it with QD first then the AIO. After applying the AIO into a panel I immediately buffed of with MF-CBT with great results.
jgv said:Menzerna products mentioned are polishes, so is the 1Z Paint Polish. Meaning they must be worked on the paint, either by hand, RO or rotary and then wipe off the remaining residues. They are not something you put coats of and let rest on the surface, in fact, it may cause damage to the paint if letting dry on it.
