SHICKS said:
Well it's A2Z x10, it will melt your bones!!!! My wheels never looked so clean, actually back in the early 90's armor all used to sell a wheel cleaner in a 16oz bottle similar to Megs WB. I was a kid and breathed a ton of that stuff, it was discontinued shortly after.
Steve
I think you were referring to this (with links to safety guidelines & symptoms of poisoning):
Professional Carwashing & Detailing Online :: Brought to you by Grand View Media
Two deaths and one case of brain damage resulting from ingestion of retail wheel cleaners have been confirmed since 1997. Two of the cases involved Armor All Quicksilver Wheel Cleaner, which was recalled by The Clorox Co. (NYSE:CLX). The product is now formulated without ABF.
Chemists say it's the flouride ions in HF and ABF that make many wheel cleaners and pre-soaks so potentially dangerous. Whether fluoride ions enter body tissues as the result of inhalation or skin contact, they cause deep, progressive burning that may quickly lead to multi-organ failure and death. Long-term exposure to even minimal amounts of ABF can lead to brittle bones, weight loss, anemia, and calcified ligaments.
McFadden says one of the most frightening aspects of fluoride poisoning is that its effects are not immediately apparent. Unlike hydrochloric acid or sulfuric acid, damage caused by HF and ABF takes place slowly.
By the time a victim feels the effects, it's too late to reverse the damage.
If a wash owner chooses to use ABF or HF, experts say the wash should be equipped with a safety shower and eye-irrigation system. If employees will handle these products, they should be provided with gloves, goggles and aprons.
If HF or ABF will be used in mist form, which is not recommended, wash employees should also wear masks or respirators.
The Occupational Safety and Health Administration also recommends employers provide a series of gels, injections and pills to combat fluoride poisoning. If these precautions sound extreme, think again.
Lethal doses of ABF and HF are estimated between one teaspoon and one ounce. A fluoride burn covering less than two percent of the body can be fatal."
From Emergency Medicine Clinics of North America May 2007:
"Aqueous HF solutions are highly volatile and produce vapors that are lighter than ambient air, often resulting in concomitant inhalational and dermal injury, especially with head and neck exposures [58]. Pulmonary effects include upper airway irritation, narrowing, swelling, and obstruction of the upper airway that may be immediate or delayed up to 36 hours [61]. Physical findings may include stridor, wheezing, or rhonchi, as well as erythema and ulceration of the upper respiratory tract [62]. High concentration HF
inhalation may result in rapid onset of noncardiogenic pulmonary edema and death [63].
Ocular exposure to HF may be the result of aqueous or HF vapor contact. Eye contact may result in pain, corneal sloughing, revascularization,
corneal opacification, and occasionally keratoconjunctivitis sicca as a long-term complication [64]."
eMedicine - Hydrofluoric Acid Burns : Article by Garry Wilkes
# Solutions of 14.5% immediately produce symptoms.
# Solutions of 12% may take up to an hour to produce symptoms.
Solutions of less than 7% may take several hours before onset of symptoms, resulting in delayed presentation, deeper penetration of the undissociated HF acid, and a more severe burn.
Consultation with specialty units may be required depending on individual circumstances.
* Toxicologist
* Burn surgeon
* Intensive care specialist
* Ophthalmologist
* Hand surgeon
* Gastroenterologist (following ingestions)
fsu.edu | laboratory safety issues
"Eye and Skin Exposure -- HF is corrosive and readily destroys tissue. Exposure of the eyes to HF may result in blindness or permanent eye damage.
HF readily penetrates human skin, allowing it to destroy soft tissues and decalcify bone. Chemical burns from HF are typically very painful and slow to heal. Skin exposure to high concentrated HF (approximately 50% or greater) immediately results in serious and painful destruction of tissue. Not only can skin contact cause burns, but systemic fluoride poisoning may also result.
One of HF's most insidious properties is that
skin contact at lower concentrations may not produce pain or burning sensations until hours after the exposure. Because of the ability of HF to produce delayed serious tissue damage without necessarily producing pain, all skin, eye, or tissue contact with HF should receive immediate first aid and medical evaluation even if the injury appears minor or no pain is felt.
Inhalation of HF Vapor -- Inhaling HF vapors can seriously damage the lungs.
Delayed reactions up to and including fatal pulmonary edema (flooding of the lungs with body fluids) may not be apparent for hours after the initial exposure. Airborne concentrations of 10-15 ppm will irritate the eyes, skin, and respiratory tract. 30 ppm is considered "Immediately Dangerous to Life and Health" (IDLH) and may have irreversible health effects.
Chronic HF Exposure --Long-term or chronic exposure to HF may result in fluorosis, a syndrome characterized by weight loss, bone embrittlement, anemia, and general ill health."
There's more but you get the picture, it's NOT an innocuous product. I hope you folks are using appropriate *safety precautions* and have a *well-equipped emergency room* nearby in case of a mishap!
