Meguiar's One Step Compound #67
gofastman
Can anyone provide me with some info on this stuff?
Over on MOL people are having really good success with #49 Oxidation Remover, but It looks like this is a step up in aggressiveness.
i have never really liked the 67....it doesnt seem to have the same oils in it that feed and lubricate the gel while your using it.....i say go #49 and have at it.....if 49 cant make it shine it needs wetsanding in my opinion.....
What gritt sanding scratches is 49 designed to take out?
For some really rough areas I've wetsanded with 220, 400, 600, 1000, then tried 49 on my 3401 with a wool pad (and orange pad) and it really didn't do anything.
So I wetsanded with 2000 then wool (or orange) and SIP and the surface was perfect.
BTW, when wetsanding gelcoat, should you have a light touch on your sanding block, or do you need to use a bit (not a lot) of pressure?
I've found that at the higher grits, if I use a light touch I don't seem to remove previous sanding scratches entirely - need use a bit of pressure (unlike on cleracoat where I always use a gentle touch)
BTW, maybe it's just me, or when you watch/read about gelcoat repair are most people crazy - they stop wetsanding at 600, then say to use a rubbing compound by hand and remove all the 600 marks. Umm...........
