Meguiar's Number 9 - Greasy
vdub_guy
This weekend, I decided to do a Meguiar's workup on the car and ran into a problem.
After applying the DACP (#83) with a cutting pad, I proceeded to apply the #9 with the PC and a polishing pad. After I was done the hood, I noticed that there was a greasy residue leftover. No matter what I did, I could not get rid of it. I called the 800 number and they said that this happened becuase I let it dry. I was told that a 2X2 (foot) section should be worked for about 20 seconds and then buffed with a terry towel. I worked it for longer than what they suggested - and therefore I have the residue.
Question: I am using the Meguiars polishing pad and a PC. What speed should I set the PC at to apply the #9. Is the information that I got from Meguiar's accurate? I searched and did not find that anyone had this issue - am I the only idiot that can't apply #9?
PC usage.
- Some prefer to only use it at 6
- Some like to start of slow 2-4 and then bring up to 5.5 (just under 6 to avoid the excess vibration)
- Some run it at 5 for everything.
It really depends on your comfort level.
For SMR, I tend to run it at 4 for a little bit and then kick up to 5.5 and work it well.
The smearing could be also be a result too much product. I am a bit surprised about the drying comment. I've noticed that if No. 9 dries, then it's can become a PITA to remove rather than it become oily.
Did you try spritzing it with distilled water and see if that help any in the removal? How about 50/50 water to IPA spritz? - That should help in the removal a bit.
20secs sound short but I've never really timed it. I probably work it 3-6x longer than that and haven't had any problems.
Just curious, what the No. 9 old, did you shake it well before use, was it v2.0?
Thanks for the info!!
I don't think that the product was old. I bought it off the shelf at a relatively high volume shop. How do I tell if it is ver. 2? What is the difference?
Hi vdub_guy,
Doesn't sound like any experience I have ever had with #9?
I have had it sort of "pile-up" and "Stick" really bad to the surface, but I have never really experienced an extra oily film that couldn't be removed?
Have you tried using a Microfiber polishing cloth?
Microfiber is better at removing oily films than cotton.
Also, I know this goes with out saying, but... did you shake it up really well before and during use?
Another question... is this an old bottle or a newer bottle.
New bottle has the black label on the front with the aggressive scale, old bottle has a maroon colored label on the front.
It shouldn't matter, because Meguiar's products have a shelf life of 3-5 years as long as they don't freeze.
For use with a PCDA, and a foam pad, use a setting between 4 and 5.
Hope this helps...
Mike
it seems to be an older bottle.
I will try your suggestions.
I have had a similar issue with Scratch X in the past too.
