Meguiar's New-For-2012 Products: Inside Scoop!
AutopiaTech
Moderator
We were able to witness Meguiar's new-for-2012 products being unveiled first hand at SEMA last week. If you haven't heard anything about these exciting new products pay close attention as I'm going to give you the inside scoop on all the new products that you will be available to purchase at the Autopia Store in the coming months.
Rinse Free Express Wash
Rinse Free Express Wash is part of the Meguiar's Detailer Line of products. Featuring a highly concentrated formula (1oz per 1 gallon of water), Meguiar's Rinse Free Express Wash enables you to safely wash your vehicle without a hose. This is perfect if you live in an apartment complex or water restricted area. With its high lubricity formula you will not scratch or marr the finish. Like other products in the Meguiar's Detailer Line, you can expect a top performing product at a very friendly price.
Perfect Clarity Glass Cleaner
It seems that the never ending search for the perfect glass cleaner continues. As a pioneer in the industry, Meguiar's knows this and is always researching and developing car care products that exceed the needs of discriminating car care enthusiasts. With their new Perfect Clarity Glass Cleaner you can safely clean all automotive glass, including tinted windows, in both a convenient pump spray and aerosol form.
DynaCone Pad Cleaner
If you've ever used the Meguiar's DynaCone metal polishing tool, you've probably been blown away by its performance and ease of use. With the new Meguiar's DynaCone Pad Cleaner, you can maintain your DynaCone metal polishing tool and all your other foam pads. DynaCone Pad Cleaner safely breaks up caked on polish and wax residue leaving foam pads like-new.
PowerSystem
Looking for a tool that makes polishing hard to reach spots a breeze with the convenience of a house hold drill? Meguiar's makes this possible with their new PowerSystem. This unique device attaches to a standard house hold drill and enables you to polish small, hard to reach areas utilizing the 4" SoftBuff pads. While it's not a replacement for a traditional DA, it's most certainly better than polishing by hand and requires virtually no effort.
Hot Rims All Wheel & Tire Cleaner
Meguiar's new Hot Rims All Wheel & Tire Cleaner is safe on all factory coated wheels! Safely clean all factory coated wheels without a worry with Meguiar's new Hot Rims All Wheel & Tire Cleaner. The newest version of this popular wheel cleaner clings better to the wheels' finish meaning less agitation is required. Loosen brake dust and road grime in seconds with Meguiar's Hot Rims All Wheel & Tire Cleaner.
Hot Rims Brake Dust Barrier
If you're looking for the ultimate means of protecting your wheels' delicate finish from brake dust and road grime grab a can of Meguiar's new Brake Dust Barrier! Featuring an easy-to-use aerosol based spray, Brake Dust Barrier applies in seconds but lasts wash after wash! Not only does it protect the wheels, but it also makes future cleaning much easier because of the super slick finish that it leaves behind. Protecting your wheels doesn't get any easier!
Synthetic X Press Liquid Wax
Part of the Meguiar's Detailer Line is their X Press Liquid Wax. Featuring a convenient wipe on, wipe off formula that can be applied by hand or machine, X Press Liquid Wax is a quick, easy way to put a quick coat of synthetic wax on your vehicle. Best of all? It can even be applied to a wet surface.
Leather Cleaner
The Meguiar's Detailer Line of products has always been about performance and value. With their newest offering in the Detailer Line, Meguiar's continues this tradition with Leather Cleaner. Featuring a pH balanced formula that removes even the toughest stains, Leather Cleaner cuts the time it would take you to normally clean soiled leather surfaces in half. It's easy to use and much safer than an APC. Comes in a ready-to-use 128oz size.
Gold Class Premium Quik Detailer
Nothing like spending the day detailing your ride only to discover bird droppings or light soiling the next day. No sweat, as Meguiar's new Gold Class Premium Quik Detailer removes light dust and dirt to restore the gloss and protection of your existing wax or sealant. Like other Meguiar's products, it couldn't possibly be any easier to make your car this shiny.
Tire & Trim Gel
Yet another Meguiar's product that replaces several. Tire & Trim Gel is part of the Detailer Line of products and is designed to be used on both tires and trim to restore a like-new appearance that dries to the touch and does not sling. A highly concentrated formula allows you to get the most out of your new-found favorite tire and trim dressing.
Headlight Protectant
When it comes time to restore your headlights, you want to work smart and not hard. Meguiar's new Headlight Protectant allows you to lock in the new-found clarity of your headlights and keep them looking new. This unique formula provides a protective barrier and locks out moisture and UV rays. Protect your invest and get the most out of your hard work with Meguiar's Headlight Protectant.
Gold Class Premium Quik Wax
Have you ever been getting ready to head to a car show and wished you had a product that was easy to use and would amp up the shine and protection of your existing wax in a matter of minutes? Meguiar's new Gold Class Premium Quik Wax makes this possible in a convenient spray. It won't discolor trim and it can even be applied in the sun.
Flagship Quik Wax
If you've ever restored the finish to a boat, you know how much work it is. After you've applied a couple coats of your favorite Meguiar's marine wax, maintain the shine and protection with Meguiar's new Flagship Quik Wax - in the convenience of a spray! Simply spray on and wipe off to amp up the shine and protection of your existing wax on your boat or RV.
Clear Plastic & Vinyl Window Wax
Meguiar's is an innovator in the industry and products like their new Clear Plastic & Vinyl Window Wax is a great example of why they've been the industry leader for over 100 years now. Designed for marine and RV use, this easy-to-use product simply sprays on and provides UV protection for vinyl windows and other clear plastics.
As you can see Meguiar's has quite a few exciting products in the pipeline for 2012. Stay tuned as I will personally be testing every one of them and sharing my thoughts with fellow Autopians. You can expect these products to be available sometime in January. We will be posting more information as it becomes available. :rockon
Still disappointed at the lack of a G110v3 or M101 being released in the US, but there are a few mildly intriguing entries here.
Do you have any information about pricing for any of the new items yet?
just a view....Meguiar's 2012
