I can not recall the exact name for that plastic, but it is a plastic, not a composite or gel-coated fiberglas.
It, as you notice is very flexible. If you were to break a peice,it can be broken, you would notice that the center of the material, moving out to less than about a mil from the outer surface, it is very porus.
This lack of density in the material allows the needed flexibility.
It is possible to wet sand the material to remove deep scratches and then polish the sanding marks out. However, then you into the porus, less dense portion of the material and can not get a high shine. This is because the dense portion that created the shine or gloss is gone.
It will always be a bit dull in it's natural state, applying a sealant or wax will brighten it a bit, but won't hold the shine or gloss.
If you do the wet sanding, use a sanding block and 1000 to start, then move to 1500.
The buffer must not be over 1000 rpm and you have to becareful to not work an area for more than a couple of seconds or it will get to hot and start to deform or even melt the plastic.
You do the first part with a cutting pad and a clearcoat compound and then switch the pad on the rotary buffer to a lambs wool,(foam just creates too much heat too quickly to use on this material), and with the lambs wool and a polish, finish up the polishing.
Then, it will be a little dull, but will look better than the deep scratches.
Go ahead and apply a sealant, will help some, and will make the unit clean up quicker.
