Meguiars APC On Carpets
Yes I have. THe disadvantages of the shields (The originals were called Kleed Wheels) is that they obstruct the airflow cooling of the brake assemblies resulting in greater risk of warping rotors and brake fade if the car is driven aggressively.
I have a set from Kleenwheels.com They work great and I have them on two cars. They are vented to prevent heat buildup, but most people I know use them only in the front. [as I did] I wish I ordered the full set. Forever cure for break dust.www.kleenwheels.com
I looked at the dust shields cuz the 330i with the SP wheels are incredibly dusty, especially the front ones. But the shields are black and with so much open space in the rims, I don't think it would look so good. The oversized brake caliper and disc is much nicer to look at. Trade-off... I applied a coat of AIO and now just use EF Hi or Amazing Rolloff and a little scrub with an OXO. I do that once a week and just rinse them in the middle of the week if it was driven in the rain (rain really globs the dust).
Maybe if they made the shield and painted it to look like a brake caliper and disc!!
H
I agree, on some wheels they would look better then on others. I have some big gaps in my wheels and black "plates" would look awkward.
I think if you have a big yellow million start wheel like the one in the pic that you should have this product :D
For those of you using the Meg APC on carpet, what have you found to be the best dilution ratio? I just ordered a gallon from PAC yesterday after every post I read, someone is using it for some other cleaning method on their cars!! I have my sis-in-law's van coming up and I know that the carpet is completely trashed, so I though this might help me get through it.
Thanks in advance.
I also ordered some P21s Gel Wheel cleaner since my Volvo brakes are the dustiest brakes known to man!!
Thanks PAC!! :Dancing Dot:
That was where I was planning on starting. I plan on using the APC and then extract with my little Bissell Spot-Bot and go from there.
I just did my truck (in show and shine forum) and used APC on the carpets at 10:1, followed up by the Bissell Little Green Machine. Worked good at removing the salt and food stains on the carpets.
Your post was actually what reminded me I needed to order some actually, thanks! And the Little Green Machine is exactly like the Spot-Bot I believe, just a different name. They also have the Little Green Pet Machine or something like that, but all 3 do the same thing I think.
Did you really saturate the carpets with APC, or just a few sprays then scrub?
Did you use APC or APC+ ?
Just a light spray on all the carpet so it's wet, not soaked, then heavy on the needed spots. Let sit for a minute, then scrubbed with a brush, reapplied to spots that needed it. Normally I'd hit just the trouble spots, but the carpets were covered in salt and various food items my 6 year old dropped (the floor mats move around alot). I used the bissell filled with hot water to spray the carpets and then suck up the APC, then my big shop vac to get them as dry as possible.
I used APC+, doesn't get as foamy, I use it on almost every cleaning task (minus windows and clear plastics as it leaves a haze). I use Folex for carpets normally, but since I was out, I figured I'd use APC+, and it worked great.
Great info, thanks!
Awesome!! I have APC+, scrub brush, and the bissel little green machine. I will definitely try your process! :clap:
I use APC+ in conjunction with the LGM. Since the regular APC foams it can cause damage to the LGM if you're not careful. When I'm not using the LGM then the regular APC works great too! :)
Is your machine similar to the Bissle Little Green?
Here is what I do...
I spray Meg's APC 10:1 on the carpets lightly, then mist the carpet with the hot water from the Little Green. I use a brush to work the APC into a lather, then extract using more water.
Yes, LGM. Is it a thick lather? I heard the LGM doesn't do well with high foam.
