Don:
What Last-Step Product ( i.e.; wax, sealant, or coating) do you have on this Camaro that is underneath the Meg`s Hybrid Ceramic Wax OR did you remove that LSP before applying HCW?
Seems to me that you used Meg`s Fast Finish sealant some time ago and that your co-workers noticed the appearance of your always pristine Camaro was even "better" or "different". Do you get comments from your co-workers about the appearance of your Camaro using HCW??
I also think that your "heavy application, two rinse methodology" might be a key to using this new product OR that the use of a pressure washer rinse may activate the chemicals better in this "wax" to make it "work" on a vehicle finish. What specific microfiber (s?) are you using to wipe down/off is HCW from the Camaro and how many are you using in this "HA-2R" process?
Your analogy comparison of HCW to Pinnacle`s Sovereign as a "beauty wax" is unique. Beauty is in the eye of the beholder. One thing that is definitely NOT comparable is the price difference. That is one characteristic that HCW has over sovereign: value for performance. If I can get 90% of the look for 25% of the price with half the effort, that`s a no-brainer bargain for me!
More questions: (What else is new, Captain Obvious!!)
1) Would you characterize HCW as a:
a) Stand-alone true Last-Step Product
b) Maintenance spray over Meg`s Fast Finish sealant or their Ultimate Wax
c) Topper/gloss enhancer, although you already KINDA answered that by saying it is NOT a quick-detailer
2) Any comparison to the much-touted Renny Doyle Double-Black Bead Maker Paint Protectant??
(I would hope other Autopians would chime in on this if they have any have tried and "experimented" with these two sprays.)
I`ll try to answer your questions the best I can, in the order asked.
What LSP do I have on the car BENEATH the HCW?
On the hood, roof and trunk, nothing. I polished those surfaces using Meguiar`s Ultimate Polish and a maroon Meg`s cutting pad, the sides had UFF applied a few months ago, but the saline spray from the snowy roads seems to have worn it down pretty well.
My coworkers definitely saw an improvement with the HCW. They have gone so far as to say that there is NO WAY that I could make the car any "Shinier." ... CHALLENGE ACCEPTED!
I`m using generic microfiber-wrapped application pads for the application and Sam`s Club bulk microfiber cloths for the drying and wipe-downs. For the "HA-2R" process, I use 3 microfiber cloths. One for the initial dry after the wash, one for drying the car after the "application rinse," and a third for the "final wipe" rinse and maybe a fourth (lightly damp) cloth for a "just for good measure" wipe to get the odd .remaining smear.
My comparison to Sovereign is not something I can describe or even show in pictures. It`s one of those: "You had to be there" things that only with the naked eye can you "detect." A subtle "over the top" thing that you have to see in person to appreciate - I hope that makes sense. And you`re right, there is no comparison on the price aspect
I would characterize HCW as: possibly "A" (like I mentioned, I`ve been applying it too often to test its durability), But DEFINITELY "B" and "C". It finishes off so smooth, so crisp and clear that IMO, it EXCELS as a topper, maintenance spray OR a gloss enhancer, though it`s definitely NOT a QD (unless used as a spray-on, rinse-off with a pressure washer).
I cannot answer #2 as I have never used Bead-Maker, or another rising favorite, Sonax PNS.
I hope I`ve answered your questions, though I`m sure you will have some more
