megs silicon free dressing
Brian_Brice
is this hyper dressing? couldnt find hd so i figured they might have renamed it, anyhow at 38dollars a gallon im giving it a whirl.
is the silicon free intended on exterior trim/plastic only? if so i dont think i need a replacement for my ext dress. i was hoping itd tackle tires as well but if not im not interested in it.
Try All Season Dressing
Can be applied on tires and trim
Run a serach I know Sean (G35stilez and ebcivics use it often)
well thats what ill use it as then sees how i dont want to go through the hassle of changing my order, im just not happy with most the tire dressings out there and trying to find a good by the gallon solution thats not gonna cost me a fifty
directly from website...
Meguiar's Silicone-Free Dressing is the choice for professionals looking for a high performance dressing which can be used in any silicone sensitive environment. Its VOC compliant formula produces an incredibly deep, rich high gloss shine on all exterior rubber and plastic surfaces.
silicon free?
I'd imagine you'd want to avoid anything with silicon in it, that might be abrasive or something.....
The silicone-free dressing was created for body shops that also did some detailing work (imagine you spending 3g+ on a paint job that looks awesome but your car has brown tires). I used all-season on exterior surfaces (after 2 weeks, it seems to be holding up) and hyper dressing on the interior. I also bought poorboys trim restorer/dressing as it claims to make wax on trip go away plus shine it. I will compare the two when i get time.
I have been satisfied with both hyper and all-season. There is really no reason to get silicone-free dressing unless you work in a body shop environment as it was created to cater to this market. Most dressings contain silicone (petroleum distiallates) so don't let that be a concern. In fact, I'm sure this is where the durability of a tire/interior shine comes from, though I am not a chemist.
Silicone on a surface will prevent paint from sticking and flowing out properly. It’s a bad idea to even bring anything with silicones into a paint shop. It’s a very, very bad idea to be spraying anything with silicone around a paint shop.
PC.
