imported_AZ Ferrari Man
Hey guys wondering if you guys know if Megs Interior Quick Mist and Wipe has any UV protective qualities? I love the matte look it provides, just hoping it has some protection!
Andrew
Andrew
miked2 said:On the bottle it says that there is UV protection . . . :\
vmunoz said:I do believe the bottle stated it had UV protection. How do you guys apply it? I gave mine away after trying it several times both spraying directly on areas or spraying on towel then applying. Each time I was left with large "dry spots" on my dash that I had to go back and re-dress. I exchanged it for another bottle thinking the 1st was bad, but got the same results. I'd like to try it again if there's a better way to use it.... just wasn't a product that worked for me. Sorry to stray off topic.
V..
BigLeegr said:I'm guessing the "dry spots" are where the QID cleaned off the previously applied protectant.
I've found the cleaners to be strong enough to remove whatever dressing is on the dash.
Even on the Megs forum, Mike P. had mentioned it has very little UV protection, so I'm inclined to think of it as a nice maint. cleaner that should have a dressing applied afterwards. (No worries of dressing build up this way either.)
