[email protected]
the shelf is now removed from my garage. I can now back in if I choose to. (not too often, as my driveway is about 60' long by 8 ft wide) I measured my garage, and of course, it has to be different than most others. Inside dimensions are 17' 2" (length) by 19' 4" wide?!?!?.. That is a truly bizarre measurement (in my opinion) That explains why I have to pull my car to within 6 in of the front wall in order to clear the door. As you can see, the garage is plenty wide enough for shelfs/counters along both sides and for 2 cars inside.
I have decided to abandon the idea of insulating the garage, and instead of sheetrock/gypsum board, I'll more than likely use white pegboard. My uprights are 2ft (on center) so 2'x4' pegboard will be simple to put in place.
I had once seen this little "traffic light" sensor that is used to measure distance from the front wall of your garage. Does anyone have any ideas where to get one.
