Mazda Protege Restored
Greg Gellas
I'm Greg :)
This car was without a doubt a challenge. It sat for about 12 months and was brought to me for detailing. Needless to say it was NOT in good shape, it help some surprises for me also....Not good ones either.
I got the car and washed it with Chemical guys citrus wash and clear....As usual I pulled the wheels and de-greased the wheel wells with purple power, while the woman took care of the wheels. :) Of course the battery was dead so I kept having to jump it until I got fed up and called the owner and asked if I could buy a new battery and install it...I got the ok...
On top of a really gross car my favorite sprayer broke...It was good cause it had a mist selection for engine bays so I didn't need to soak them...:( I knew this car wouldn't be fun right then...
All washed I pulled the car inside to clay using dodo juice and I used some mothers clay. While the Laura started on the interior...Its really nice having her help. :thumbsup:
The hood...:mad: It was a CF hood and it was a real Pain to work with...I would do a full three step and it still wouldn't come out right, it still would have some what I could only explain as cloudyness...I called the owner explained that I had already spent over 5 hours on the hood alone and it wasn't coming out PERFECT but it was without a doubt an 80% improvment is that ok....He agreed that anymore time spent on it would be a waste. He also asked me to replace the screws on the grills.
It turned out well. Considering how bad it was...:o
So Laura was working on the interior and found ALOT of mold all over...Needless to say she was less than happy to work on that stuff...I decided to heat up the steamer to kill the mold....I love the toys :D
She also had to deal with leftover adhesive from window tint....Luckily I had a great juice that just melted it away :) And to think I get in trouble when I buy new products....:D
The entire interior had a musty smell even after the cabin was cleaned and steamed. She had to go do some stuff so she left me the trunk to do...OH BOY was I in for it. I pulled his sub and amp and the trunk carpet and well I found this.
Obviously the car has been leaking for the 12months its been sitting there and filling up with water into the trunk. Initally I sucked the majority of the water out with my wetdry vac. I then pulled the drain plugs and rinsed everything with HOT water. Not only did I steam the entire carpet outside I also steamed it while it was in the car. Did I mention I like TOYS :D
I had to do a full 3 step on this car...I did a purple wool pad with SIP, moved down the 203s with an orange pad, and finally finished out with 103 on a white. I proceeded to Ez-Creme glaze the car and finished it up with Blackfire Wet Diamond with Polycharger. I have been using that over opti-seal recently cause I usually have to wax to add slickness to the opti-seal and with the Blackfire it ends up slick.
Laura used Folex and 303 on the interior I don't even check on the interior anymore she does her thing and it comes out great. :)
I only have afters in the garage as the owner picked it up tonight...But enjoy, I am going to bed so I can get going on another car that is getting dropped off tomorrow...;)
I am always mystified how people can just leave a car to sit and not expect problems. Nice turnaround on the Protege.
A huge turnaround on the vehicle. Great Job!
BTW, what kind of steamer do you have? I am thinking about picking one up.
jeteast99 said:
I cant see the pictures
:o Ran out of bandwith, fixed now :D
The steamer is almost identical to the Polti Vaporetto 2085 Steam Cleaner....It basically the older version of the 1030. AllBrands.com - Polti 1030R Vaporetto Steam Vapor Cleaner, DVD, 4 Casters, 1500W, 13A, Safety Cap, 1.5L Boiler 370°F, Working 270°F, 0-50PSI, 0-70 Grams /Min - ITALY
Wow, well done there. Good turnaround.... you won't win with every car but even if you didn't win every battle with that one, you won the overall war on the cr@ppy condition it arrived in!
KaPow!
:wavey Thanks guys. Yeah that car still haunts me :D
I had to get it done in 2.5 days cause I had to get it out of my garage cause I had another car come in. The owner was estatic at the job which is always good
I'm amazed you can get enough $$ out of a detail this extensive to make it worthwhile. When I see the high-end cars here, I assume the owners have the cash to pay for the extraordinary work. However, when I see a rusty, moldy, peeling tint, dead battery, water leaking Mazda Protege, It's surprising that the owner had (and was willing to spend) the money to allow you to do everything you did! I would expect everything you did to run at LEAST $500.
Congrats on great work - I think a lot of people would have walked away from that one!
Apollo_Auto said:
Nice clean up guys! Looks like a couple of science projects were terminated with this one :).
Yup Mr.Wizard would have been mighty upset :D
David Fermani said:
This detail job rocks. One of the most hardcore projects to hit the screens of Autopia in a while.
Thanks that means alot! :thx
Remember I said the car sat for a while. That was due to the owners loss of license. So he was able to bank money for 12 months and pay me to fix his leaky car :D
:soscared: It came back....:mad: So it has continued to leak since the last correction on the mold I did. I discussed with the owner that I don't want to continue to just correct the mildew, but fix the issue.
I decided to measure exactly how much water was sitting in the bottom of his spare tire well area....
Of course it wasn't just in the wheel well area, but on both sides of the trunk....:bawling:
Since he is a buddy, I researched exactly what causes the leaks. Apparently any slight hit to the rear of the car causes some of seams to pop and allow water inside. We discussed what to do to "seal" it and decided that rubberized undercoating was a cheap yet effective solution. How to find the leaks.....:D You have your helper stretch and then crawl int he trunk, and shine a light in there to see exactly where the holes are :D
He had to flip around to see the right side :)
We found the seams that a popped allowing water to be let in....Taped them off to prevent too much rubberized undercoating to get to the headlight area and went ahead and "sealed" the leaky area's. You can see exactly where the paint has chipped off right under that the seam has seperated also. I know its a sloppy job on the spray, but its all hidden and I wanted to ensure he didn't have any additional leaks. Also although it looks brown there, it really did dry Black...:D
I pulled the drain on the spare tire well and let the nasty smelling water out....
Ok back onto the acutal correction here :) I used some mold and milew in my steamer and dilluted it. The entire car had a stale smell to it so I wanted to kill all the mold and bring back a clean smell.
I did a 50/50 on how effective the steamer really was on this trunk area :D
Don't forget the little lip on the carpet :D
All things considered, not toooooo bad a result :o
I steamed the carpet and then put everything back in and orgainzed the trunk for the owner.
:2thumbs: Thanks for checking this car out again....:thx
