Makita 8"pads on my PC?
GlossyTundra
Tractor Detailer
My local ACE hardware store has two 7.5 or 8" (cant remember the exact size). One is a wool pad and one is a waffle pad probably made for a rotary. Wondering could I use them on my PC. Looks like they would work just fine.
Thanks
Hey Brandon1, I just bought and tried to use Meg's 8 inch pads on my PC. They don't seem to work to good. Mike Phillips with Meguair's said the 8 inch are for a rotary and they spread out the effect of a PC over to large an area. This keeps you from being able to do any paint removal to correct problem areas. That seems to be what was happening when I tried to use them. Mike at Meg's is an expert on detailing and a good guy. Hope this helps, Wes
IMO the larger pads work OK for glazes and LSPs, but not for polishing. The PC will bog down faster and won't be as effective. In fact, for polishing/paint correction, I prefer to use *smaller* pads than normal, 4" ones.
