Aurora40 said:
Can you spin the pads freely when the Cyclo is off? I was under the impression (also from the fact a wrench isn't included) that this was not the case. If they move from the motor, then it isn't really random-orbit, it's a direct drive maching that just isn't a rotary but rather direct-drive in an orbital motion.
Hey, good observation :xyxthumbs Heh heh, I've used this thing for over 20 years and yet that never occurred to me when posting about it
[Accumulator pauses to
about his carelessness and shallow thinking and to commend Aurora40 for his big, and well-engaged, brain
Yes, the heads are directly driven. If you move one, the other moves too and they move in fixed, elliptical orbits. This is backed up by a line in the manual that says "the two heads are timed exactly 1/2 turn apart". No way for something that's "random" to also be "timed ... apart". And the diagram of the machine's internals confirms this. There is an "idler gear" that engages the two "drive gears" which attach to the (solid) counterweights via bearings. The counterweights/heads can spin freely (rotationally) on the bearing, but the orbits are fixed.
This would explain, in part, why the Cyclo is "more powerful" than the PC. So maybe it *should* be considered a "sorta rotary" after all. But I've *NEVER* had any "rotary-type" problems with it, certainly no holograms (in fact, I've used the Cyclo to *remove* them). If anything, I sometimes find the Cyclo easier to use because it seems to more consistenly do what I expect than the PC does.
As far as the wrench, both of *mine* came with one. It *is* necessary to remove the heads (because of the free-spinning bearings between the heads/counterweights and the drive gears).
I also thought it odd that the specs mention a 2 amp motor, but everyone claims it feels more powerful/less bog-prone than a PC. I wonder if that's due to the lower speed and smaller pads rather than actually having more power?
Got me there :nixweiss I don't think it's just the smaller heads, though. I know what you mean (more concentrated application of effort), and I've used the smaller plate/pads on the PC. No comparison, the Cyclo is more powerful. Probably because of the features discussed above. This also holds true when comparing the PC at a similar speed setting.
Gee, I sure hope this doesn't discourage anyone from getting one, or, conversely, give anyone unrealistic expectations.
Again, a *big* :xyxthumbs to Aurora40 for leading to (hopefully) further clarification of how the Cyclo works.
