baseballlover1
What is it? It seems my rotary developed a little squeak. I have had it for about a year. Is there anything i should be doing to it to keep it working perfectly?
fergnation said:I had to replace my power cord last week due to a short in the white wire. My cords always get twisted and I haven't found a way to remedy this yet.
baseballlover1 said:... I have a feeling you guys may be right about the rust... i have left it out a little bit and i also am known to spin dry my pads and sometimes they are not completely dry... should i take it apart and inspect? Or just blow it out? I LOVE my rotary and it has been very good to me!
Also... i took out the brush tonight... its not exactly a brush. Its a kind of block... does anyone else know what i mean?
fergnation said:If you have only had the 9227 for about a year I am pretty sure that the brushes are fine. there are many a detailer that use this polisher five to six hours a day for many years before the brushes start to have problems. Although now that I have said this, mine will probably burn out on me tomorow.
Baseball- brushes usually have a burned look to them when they go bad. If you have a squeak I would think it might be something caught in the gear. Also, if you don't get your pads dry, a lot of times moisture can permeate inside of the case and cause rust. This can also happen if it is stored in a damp or humid environment. I would follow the steps from above and hopefully that will take care of the problem.
Best of luck to you. The 9227 is one of the better rotaries and also one of the most durable.
KnuckleBuckett said:Use split loom.
KnuckleBuckett said:Um...
Use a new cord. No cutting required. Just pop the split loom onto the new cord. If appropriately sized it shouldn't take more than three or four minutes.
