LSP for salt- WG PS, 845, or 105TPP?
Ok, so just finished polishing my Range Rover with Pinn. ASR and AFP, and am about to head to VT for the weekend. I would like to do 105 topped with 845, but simply dont have the time. This has to last me to about the end of March with the strongest durability possible. What would you do? I can only have one LSP because of the lack of thime.
Thanks a ton!
Either 105 or 845 will provide you with more than enough durability and protection for the short term. Either would be a fine choice and will easily get you through March on 1 coat. Both are easy to use and both look great. I have found the detergent and "crud" resistance of 105 to be outstanding. It will bead through the dirt!
I have had 105 on since late August and it is holding up fine..a spray wash and its clean..dirt just rolls off it...salt does not hurt it like some others I have used...your fine with just the 105 till March...it will bring you to June easy
Al
Buff it off first..then tomorrow do AW...better results....105 needs to cure..if you use AW now you may push the uncured 105 and get streaking...
Al
