I have a friend who bought a `11 Corvette Grand Sport with a removable hardtop. His problem is that the seals will squeak when the top is installed.
Apparently , Chevrolet is aware of this problem and has a "fix" with a seal lubricant that my friend says cost $85.00 for a 5-ounce tube through the Chevy dealer part department!! (Common on now; this is not a Porsche or Ferrari, it`s a GM!). He has researched this problem on Corvette forums and found a suggestion to use Silicone Di-electric Grease (IE, spark plug boot grease) as a cost-effective substitute, BUT when he tried it, it only lasts for a few days and the squeak is back.
Does anyone have any suggestions of suitable cost-effective substitutes that might work?
I am not sure if Nextzett Rubber Care Stick Gummi Pflege or 303`s Rubber Seal Protectant may work, as these are water-based and not a grease-type lube for a "more-permanent"` solution to the squeaky seals.
