it might be worth the drive to see someone like member Big A detailing (andrew). applying opticoat is not that difficult, but you want to make sure the finish is as good as you can get it before you coat it & that takes more talent. because it's a semi permanent coating that you can maintain with simple spray on detailers afterwards, it might be worth the drive to have an master like andrew do it. his work is outstanding.
if you think the finish is good enough for you now, check out todd's write up and do it yourself. it really is pretty easy to apply. http://www.autopiaforums.com/forums...ehensive-opti-coat-2-0-application-guide.html
