jgv
I'm here!
rtbrick said:I'm sure that P21S is a great wax, but it is still just wax, right? The durability is still subject to weather, environment, etc. Why not just use a much longer lasting polymer and skip the plain wax?
Be gentle in your replies...I'm still new at this...![]()
If you top your UPP with a wax, you will need to remove that wax before you can apply more UPP. As far as topping UPP with a carnauba, I did the S100 over my AIO/UPP treatment and really didn't think it was worth not being able to apply more UPP whenever I wanted. Try one area and see how much difference it makes. Maybe for you, it will be the way to go. By doing only one area, you won't have much wax to remove to go back to the straight UPP.rtbrick said:So how often does one repeat the polymer process and how often for the wax? What would it do with my UPP application? Many folks sing the praise of UPP and EX as they stand alone.
CharlesW said:If you top your UPP with a wax, you will need to remove that wax before you can apply more UPP.
