TrKent
Here goes the first post in this forum =)
Here is a video & some photos from a Lexus I recently worked on. The water-spot etchings were so bad on the horizontal panels that I had to resort to Surbuf & 100/101, even on the glass!! The finish was then further refined with PolishAngel Invincible 9H Primer & protected with Color-Matched Cosmic, specifically formulated for this paint code.
[ame=http://www.youtube.com/watch?v=M8wwOehHa0Q]Dream Detail - Lexus ISF with POLISHANGEL® Cosmic 9H - YouTube[/ame]
IronX
50/50 on the roof with Surbuf pads & Megs 101
Before:
After:
Before:
After:
Rupes LHR21 on the hood with Meg's MF pads & M100
Followed by PolishAngel Invincible 9H Primer. I have found this polish works very well as a 1-step polish, perhaps an alternative to Perfect Finish as it has tremendous cut with a super high-gloss finish. This also has the added benefit of not needing an IPA or Panel Wipe before applying Cosmic 9H
Polishangel Palladium, super easy to use metal polish. Either I have been getting very easy metal to polish or this works much faster than what I am used to.
Hood reflection shot just a short while after applying Cosmic. It takes Cosmic 24 hours for the full gloss & hardness to set in.
Reflection can sometimes be hard to capture on a Pearl White but this was reflecting quite nicely, the pictures don't really show it all.
Check the label on the box here, Lexus paint code 077.
IronX
Before:
After:
Before:
After:
