Leave swirls in the past with the latest in polishing technology from Optimum!
Todd@RUPES
Just a regular guy
Leave swirls in the past with the latest in polishing technology!
Optimum Polymer Technologies is a small company that has been making big waves in the detailing industry since 2001. Based out of Memphis, Tennessee, Optimum Polymer Technologies was founded by Dr. David Ghodoussi, the former paint polymer chemist for PPG. Optimum Polymer Technologies' motto is “Accelerate Into The Future” and the continuous advancements Optimum puts into each new have kept to that statement.
Optimum new's polishing system, the Optimum Hyper Micro System, combines several cutting technologies to make your machine polishing results easier while producing perfect results. The Optimum Hyper Micro System combines several new and cutting edge technologies to accelerate your polishing into the future.
Advancements:
Polishes utilize spray technology to deliver an uniform amount of polish to the pad
Latest in microfiber pad technology for dual-action and rotary style buffers
Compound uses the latest in refined aluminum oxide “non-diminishing abrasives”
Polish uses the latest in refined aluminum oxide “diminishing abrasives”
The results of these technologies is a two step paint correction system that gives the dual-action polisher almost as much paint polishing power as a rotary polisher, while creating a flawless result, even on soft black finishes.
The Optimum Polymer Technologies Hyper Micro System includes Optimum Hyper Compound Spray, Optimum Hyper Polish Spray, Optimum Microfiber Compounding Pad, and the Optimum Microfiber Polishing Pad.
The Test Panel:
This trunk lid has been sprayed with extremely soft base coat / clear coat in black. This allows us to test products to the extreme an analyze their performance accurately. I created swirl marks in the paint by rubbing a stiff bristled brush over the finish. The result was deeper swirl marks that are far worse then what you would find on your typical daily driver (unless you have been washing your car with a stiff brush!).
The marks were so deep that they were easily visible under fluorescent lighting.
Igniting the paint with a Brinkmann Swirl Finder light showed how truly bad it was.
Step One: Optimum Hyper Compound Spray & Optimum Microfiber Compounding Pad
Optimum Hyper Compound Spray is a unique spray on formula originally designed for OEM (factory) application to provide fast repair of paint defects while minimizing paint product waste. This cutting edge Compound uses several advancements in paint polishing technologies, including a very unique abrasive that maintains an even amount of cutting power through out the polishing cycle. This gives Optimum Hyper Compound Spray the ability to remove paint defects quickly, even when used with a dual-action polisher, while maintaining a high a high gloss finish that only requires minimal final polishing for a flawless finish.
The Optimum Microfiber Compounding Pad uses the latest technologies that utilizes the orbital action of a DA polisher to give it cutting power that is near rotary level while maintaining the safety and ease-of-use that dual action polisher users have come to expect. The combination of these two products gives the user a safe way to correct serious paint defects.
Start by centering the Optimum Microfiber Compounding Pad on the backing plate. For this test I am using the Porter Cable 7424 XP random orbital polisher.
Apply Optimum Hyper Compound Spray Polish to the pad by holding it approximately 6 inches away and squeezing the trigger quickly. For fresh, dry pads, use two sprays. Once the pad is primed, use only one spray for an additional section.
The compound is evenly dispersed onto the pad's surface.
The same principals of machine polishing apply to using this cutting edge system. Drape the cord over your shoulder and hold the machine comfortably. Work a section at a time, approximately 2' x 2'. If you need more cutting power you can shrink the work section down. Polish on speed 5 or 6, using firm pressure (enough to slow the rotation of the towel but not enough to stall it completely) and move your arms in over lapping passes.
Here is the one exception, with most polishes and compounds, you work until the polish “break's down.” In the case of Optimum Hyper Compound, you work until the defects are the removed. That is because the advanced “non-diminishing abrasives” will continue to work as long as they are applied.
Work a 2' x 2' section with firm pressure on speed 5 or 6, with slow arm speed and firm pressure in overlapping passes.
Optimum Hyper Compound has an incredibly long work time, work until you can no longer see defects or the compound becomes clear.
Buff of the residue with a soft microfiber towel, such as a Supreme 530. Hyper Com pond buffs off with incredible ease.
Microfiber Polishing Pad's Quick Tip: As you polish with any microfiber pad the nap will become flat and pressed down. This changes the dynamic of the pad and significantly reduces cutting ability. To keep the pads clean (for the best finish) and keep them fluffed (for the best cut) it is important to clean your pads frequently. The best way to clean them is to blow them clean with an air squirter attached to an air compressor. If you don't have access to this, use a nylon bristled pad brush.
The fibers have become matted down.
Run the machine while pressing a nylon pad conditioning brush into the nap.
The pad is now fluffed and clean and great for additional product (and the next section).
One of the benefits of both the advanced Microfiber pads and the Hyper Compound is both leave a very nice finish (for a compound). There is very faint haze in the paint at this point (which is incredible considering how soft the paint on the test panel is).
Here is the before side...
After compounding (not final polishing)...
And a 50/50 split shot....
Step Two: Optimum Hyper Polish Spray & Optimum Microfiber Polishing Pad
Optimum Hyper Polish Spray is a unique spray application polish that uses ultra refined diminishing abrasives to burnish the paint to a high-gloss shine. Just like all Optimum polishes, Optimum Hyper Polish is extremely easy to use and has a long working time with no dusting or sling issues. Its spray application minimizes the chance of overloading or gumming up the pad, and it provides an even application. Optimum Hyper Polish easily wipes off with a damp microfiber towel, whether you use it in the sun or shade, to achieve outstanding results.
The Optimum Microfiber Polishing Pad uses the latest technologies that utilize the orbital action of a DA polisher to give it good polishing power while maintaining the safety and ease-of-use that dual action polisher users have come to expect. The combination of these two products gives the user a safe way quickly and easily remove light defects and create a stunning, flawless finish.
Start by centering the Microfiber Polishing Pad to the backing plate of your DA polisher. Mist Optimum Hyper Polish Spray onto the Optimum Microfiber Polishing Pad in the same fashion you did with the compound. Use two sprays to prime a pad for initial use and one spray per section after that.
Optimum Hyper Polish Spray uses traditional like abrasives that do break down, so continuing working until the polish appears to 'clear' on the paint surface. At this point reduce to speed 4 and continue working for an additional pass maintaining firm pressure. Then buff away residue to reveal a high-gloss, swirl-free shine.
Optimum Hyper Spray Polish uses a diminishing abrasive that will achieve best results when broken down. Here is the film on the paint when it is fresh.
Work in smooth, overlapping passes, until the polish breaks down (becomes clear).
At this point, with the polish nearly translucent, the polish is ready to be removed with a soft microfiber cloth. That's it, your done. Having a flawless finish can be that easy!
Always inspect your work as you go. Here I am looking at the paint with a Brinkmann Swirl Finder light.
Here is the paint finish under the swirl finder light.
Remember how pad it was before, even when viewed in standard garage fluorescent lighting? Here is the polished finish now.
This is a good time to remove the masking tape in order to compare the polished and unpolished sides directly. Always remove the tape at a sharp angle to the body to avoid lifting it.
Under the standard fluorescent lighting...
With the Brinkmann Swirl Finder light...
The true test of paint is how it looks in the direct sunlight. Luckily it was sunny day in Florida, so I pulled the panel outside to inspect.
In the sun the finish was FLAWLESS!
Here is the unpolished side.
Another direct sun picture of the hood to show the quality of finish.
A 50/50 split shot.
One more pair of polished vs. unpolished pictures.
Conclusion:
Optimum Polymer Technologies continues to “Accelerate Into The Future” by combining these advanced technologies with a novel application. The result is a polishing system that gives dual-action polishers the ability to remove defects like a professional wielding a rotary tool. Best of all, the considerable safety margin of a DA polisher is maintained.
While most polishing systems require 3 (or more) steps to remove heavy defects from the paint, Optimum is more than capable of doing the same in two steps, quickly. Whether you are professional detailer or a novice enthusiast, Optimum has a polishing solution that will save you time, increase your results, and maintain safe polishing.
Hmm...very interesting.
I really like the idea of there being no dusting with this polish. But the real question is, how do you feel it compares to Meg's M105/M205 tandem and the tried but true Menzerna line?
Also, any idea of how it behaves with the Flex 3401 machine compared to the Porter Cable?
-J
I am also very interested in how it works with a Flex.
When you say incredibly long work time, how many passes does it usually take? M105 is very short but wondering if closer to the Menzerna work times.
That's quite remarkable. It also begs for another demonstration with a very hard clear/surface to see how it does in that situation.
Really like the sound of this. Menz and 105 are great. The only draw backs are dust or heavy oils. Where does this fall in?
Al, I tested exclusively with flex and the working time is less with 105 than with a traditional foam pad and with less dust to! I found that 101 cuts the best and little time with almost no dusting! Menzerna is about the same, maybe a little more time. I haven't used up my 85RD so I can't tell you about the new version. But with the polishing pad 85RD finishes down pretty nice.
I guess we now need a comparison between microfiber pads and foam pads. Just when I think I'm starting to understand all of this you add another pad type.
Lets not scratch the AMG. Mr Todd. Does that mean that the compound removes defects chemically and not with the abrasives? Good for new soft clear coats? A lot less buffing time. Is it anything like the XPC3 correction system? That panel looks great and i have the perfect subject in mind.
-J
I try to avoid direct comparisons, particularly when they involved "which is better" but I will try to answer your questions as best as possible.
Optimum Hyper Compound Spray doesn't quite have the same rate of cut as M105 but because it continues cut for a LONG time, I seems that it could equal the cutting power application for application. It will just take longer. Optimum Hyper Polish Spray, on this soft paint, definitely
left a flawless finish.
They pads work extremely well on a Flex 3401.
The working/play time is about as long as Menzerna. Because Hyper Compound Spray uses non-diminishing abrasives, you rarely need to use all of that working time.
There was very light dusting when I over worked the Compound (I tried to get it to dry). It is a wetter product, so wipe off isn't quite as easy as something like M105, but it seems to be far easier than Menzerna. It wasn't difficult at all. I did strip the panel and noticed no filling on this particular paint.
The compound is abrasive, it uses non-diminishing abrasives.
i haven't tried the compound spray but i did use the polish on my f150 last year with a white ccs pad with my makita and it came out amazing. all my co-workers were asking me what i used.
Yes, after doing to this test I was really impressed with the finish by the Spray Polish. It is another winner from Dr. G!
big-ups in the ease of use category. the very nice finish results speak volumes. do you need any special backing plate to use with the opt.mf pads ?
