tssdetailing
I'm looking @ LeatherMagic's website and need some dye for an 01 Audi A8, what is the difference between an Aniline Dye and a Color Coat? What application is each suited for and what would I need for this project?
Shiny Lil Detlr said:Maybe Accumulator knows? He's got an A8....
judyb said:The best analogy to use is to think of wood. On wood that has been stained (dyed) you can still see all the natural patterns but if it has been painted you can no longer see these. You therefore would not use a stain on a piece of painted wood.
Hope this helps
Judyb
judyb said:Aniline leather in cars is rare but does exist so needs to be understood by detailers.
On a personal note I much prefer aniline to any other leather and if taken care of correctly can last a lifetime which is not usually the case with pigment coated leathers. Aniline restoration is much easier than pigment restoration so if you have not had experience with recolouring I would be very careful about the products you choose as most of the DIY products on the market simply do not work and can cause long term problems.
Pigment restoration is very much a process and all the steps are crucial for good results.
Hope this helps
Judyb
