David thank you for the complement:
Let's look at leather cleaning as if it were are own skin. Our skin is the largest living organ. When I started Paramedic school in the late 80' I remember my professor asking the question. What is the largest organ in the body... It turns out to be our skin.
I want to bring to the table an interesting analogy to compare to leather interiors. Summer temperatures in the United States can climb above 100 degrees Fahrenheit (38 de grease Celsius), making heat stroke a big problem for heat stroke.
ATTENTION all detailers. This information can save your life. The human body wants to stay at 98.6 degrees F. The only way to stay at 98.6 is to sweat. By putting moisture on the skin and letting it evaporate, your body can cool itself very effectively and keep its temperature in the proper range.
Sweat works really well as long as there is plenty of water in your body -- it takes water to manufacture sweat. If you run out of water, sweat stops and your body rapidly overheats. It turns out that it is extremely easy to run out of water -- your body can produce 0.5 gallons (2 liters) of sweat every hour in a hot environment. Unless you are drinking water at the same rate, you will dehydrate and then stop sweating.
Your internal thirst meter often is not sensitive enough when you need that much water (and it has been said that by the time you feel thirsty, you're already dehydrated), so you have to keep drinking regardless of how thirsty you feel. Your body can produce a half gallon of sweat every hour in a hot environment.
The other thing that can lead to heat stroke is very high humidity, which keeps sweat from evaporating.
In either case -- be it the lack of sweat or the inability to evaporate it -- the core body temperature can rise very quickly if it is hot outside. Once the core gets to 106 degrees F, it is a serious problem.
a car is an excellent solar oven that uses the greenhouse effect to trap heat. Sunlight heats the sheet metal of the car, and it streams in through the windows to heat the interior. It turns out that glass is completely transparent to visible light but opaque to infrared light -- and infrared light is the heat that is trying to radiate back out of the interior. So the temperature rises rapidly, to the point where you often cannot touch the steering wheel without getting singed.
This is why I explained how important it is to me to steam clean leather. I want all the trap dirt, body oils,conditioners etc to be cleaned off. I want to start with a new clean leather so I can apply conditioners. Note that a lady when she goes to her favorite spa, she will go for the full detail. Her skin is a #1 priority. Her face means the world. They get the steam to there face to release or types of clog pores,black heads, makeup, grime, germs and oils.
They want to always have there face to look younger, fresher. Then comes the green face with tons of ingredients and the massage to there face. And let's not forget the big round cucumbers. Bless all the lady's for taking care of themselves. Now in the other hand imagine if a lady was not taking off her make up and would re apply makeup the next day. No comment.
Guy's (VERRY IMPORTANT) we to need to take care of our skin while we are in the sun by using sun block. Some of us including myself Will take better care of our clients leather in there cars and neglect our own skin. Leather needs to be hydrated and treated right. When you put conditioners on your skin or certain oils it's for nourishment. Providing that your skin is clean, it won't clog up the pores if you maintain the skin properly. Same goes for leather.
If the the leather is not treated correctly it could get hard or lead to dry rot. Well after writing all this I'm taking a steam bath and drinking a large glass of water. I think I will even put a pair of 2 inch jeweling pads on my eyes with coconut oil. Don't let the heat, stroke you down. Keep pressing on.
Regards
Eddy Fiuza
PS
Private message are always welcome if you have any questions. Or you can email me or visit my web-page.
http://fiuzasautodetailing.com
