LC Variable Contact or Constant Pressure
impulsebrklyn
I was looking to order a set of these from danese as they are on sale. Cant go wrong for 40.80 for 6 pads.
Lake Country Foam Curved Edge Variable Contact Pad Package
http://store.danase.com/focuedvacopa.html
But then i noticed something different alot of the other websites offer full contact or constand pressure pads. Are these the same??????
Are these LC pads??? Hi-Gloss?????
http://www.premiumautocare.com/advanced-foam-pads.html
Same pads differnt site!
http://www.properautocare.com/ad712inhipa.html
1. Can someone explain which is better variable or constant pressure??
2. Is full contact and constant pressure the same thing??
3. Are the Hi-Gloss pads made by LC??
4. What do you recommend. Currently have a PC and my Metabo is on the way.
Thanks Chris
The pads that you lnked to are all the same thing. They are 7.5 inch pads from LC. If you will notice, all the pads have a hole in the center. These pads are best used for a rotary but can be used with a PC.
The other pads that you mentioned are 6 inch pads best used with a PC but can be used with a rotary. These pads do not have a hole in the middle.
This is my understanding of the pads that you mentioned.
With the PC the constant pressure pads are the way to go. Very easy to use, VC pads take some getting used to even with a PC.
