LC System 2000 Pad Washer & Grit Guard Universal Pad Washer
Bert
Active member
Has anyone tried both? Which did you prefer?
If all you use is foam I am guessing the Grit Guard would be better since agitation against the grit guard would be a little more effective than against the spurs of the LC System 2000.
On the other hand, if you use wool also, how well would a Grit Guard (rather than spurs of the System 2000) do with wool strands?
I use wool for correcting so my guess is I should go with the System 2000.
AeroCleanse said:
I have the Grit Guard and its great, even on wool pads. It can also work with the PC 7424.
OK. I figured wool pads would need something that can "dig" into the wool and clean it out like spurs.
My pad washer arrived today along with about $400 in pads from LC- Kompressor and 4" foam! So excited to start some R and D with Optimum and LC pads.
Rob Regan
