LC Orange flat pad problem on PC (Newbie!)
kapinnn
I've read a few threads here about problems with pads but did not find a solution for this.
I just used a PC for the first time this weekend to get rid of some swirl marks and scratches on a friend's car and everything started well. I used an orange LC pad with SSR 1 to do half a door and was impressive at how easy it was going. I did the other half of the door with SSR 2.5 on an orange pad and it worked a bit faster and no extra fine swirl marks. I then proceeded to the other door and trunk.
Once I got to the trunk I looked at the pad and it seemed like it caved in in the center. As if the foam in the inside had melt and moved to the sides. The center of the pad is like a hollow pillow now. I was using very little pressure, using speed 3 to spread the polish and 5.5 to 6 to work it in. When I removed the pad from the velcro backing plate I noticed the center of the velcro was melt.
My guess is that the screw part of the plate was absorbing heat and transferring to the pad, how can I avoid this? I've read that people used the same pad on the PC for hours with no problem. I was probably polishing for about 45 minutes to an hour.
Sorry for the long post and I appreciate any help!!!
