You might never wash your car the way you normally do, again. I know this is extra long, but I wanted to be super specific and show pictures, and I’m excited because I was completely happy with my refined detailing method, but was never happy with my same old ineffective washing method, UNTIL NOW.
Let me tell you first off that Pinnacle body wash rocks. From Don and Punk's (and others’) testimonies I decided to get it. I knew that this stuff would foam up a storm and I decided to take advantage of that completely.
I hate the way I wash my car, no matter how many buckets or how many mitts or whatever, it’s just not effective (that is everything gets all dirty). I’m convinced that a big old yucky mitt just isn’t cool (I absolutely dislike putting a clean mitt and rubbing it all over a visible dirt layer on a panel. The only part I like about soap is the foam and the foam only. I basically pull the foam off the top of the bucket and spread that lightly on my paint, but after a few seconds the foam gets water gets contaminated (despite rinsing my mitt) and it’s cumbersome.
So here’s what I did. I put about a teaspoon or a little more of the shampoo (smelled nice) and filled the rest with water, in what used to be a foaming face wash dispenser (cleaned out really well). If you are unfamiliar with these its like a soap dispenser but it draws in air and out comes all foam rather than just soap (see the pic).
I started on my wheels and dispensed a pump or two of pinnacle suds and used my bare hand and soaped up a wheel completely. Then I moved on to the second wheel and did the same keeping the first wheel soaped. The foam worked really nice at staying put providing scrub free cleaning action. I did all the wheels and then I had a thought. Why not don’t I try this on the paint too?
So here’s what happened. I wetted down the whole car (in the shade of course) (nice little water beads all around). Then one panel at a time with dispenser in hand I soaped up the entire panel, not even barely touching the panel but with the thick rich foam itself (no mitt, just hands) like applying shaving cream on your face. I then thought, what happens if my hand gets dirty? So I filled a clean bucket with water and every few soaps I’d dunk and rinse my hand. Then I went over the foamed spot with my hand (this worked really when cause you could feel every spot (so smooth) Then I got to a lower panel and thought that I needed more “scrubbing� ability for the bugs and bigger dirty spots. Ended up soaping the lower panel letting it sit for a minute or two then I followed it up by more soap on one of my mini microfiber towels. The little bugs came right off and it was so smooth and it rocked and now I’m convinced that this is the way I’m going to wash my car (when I can take the time) every week. I didn’t use a mit, nor 2 buckets of water and I found out the little microfiber clothes make excellent scrubbing cloths, and I used less than two teaspoons of soap with some in the dispenser to spare. You can do each panel in any order cause you will have new foam and a clean rinsed hand; it rocks. My car never looked better and I am reassured because as I soaped with my bare hand I could get all the little “rough� spots to a butter finish.
Now I know everyone has there own way of washing their cars. You guys are the most diverse and open people to detailing techniques. Go out and get a foaming dispenser (I’m not sure if they make them without stuff in it), so you might have to sacrifice a face cleaner or dial foaming dispenser. But you have to try the wet a panel, a foamy hand, and mini MF method. The endless amount of foam stays white and I’ll have so many washes with the amount use, I even had to rinse really well because the foam was all over (this has now just been a patented process by me
) Just look at that picture you can’t get that much foam unless you over use soap and refill your bucket. "Trust me, you won't be dissapointed" (my Don line <-- )
