Layering Optimum spray wax
jlineman
I know Optimum spray wax can be layerd. Any thoughts on how much time I should wait before a second coat? Also their web site shows it being put on with a buffer. Any advantage to that, maybe better shine? Lots easier to just wipe on and off by hand. This has probably been discussed before but I can't find it. :think:
Any help appreciated.
Lineman
You can apply up to 2 coats in the same day. After that, allow at least a day before
putting on any more.
OCW can be applied by hand or machine. Here's what works
for me:
Spray a small amount on the pad to prime, and spritz a little on the panel.
Set PC (or your favorite D/A machine) to the 3 setting, and make single overlapping
passes. No need to apply any pressure; just use the weight of the buffer. The
coats should be thin enough that you can barely see it on the paint.
Wipe off with a plush towel, flipping or folding over the towel regularly to a dry
section.
MARCOSTAN said:
What's the max layers can I apply?
Can I use OCW as QD for claying?
I dont see a reason why you couldnt just layer it forever. Treat it like any other LSP. I wouldnt use it for claying since it takes so little to wax a car, you'd be wasting a TON of product. Why waste a $15 bottle of awesome spray wax, when you can use up a $5 bottle of QD or a drop of wash soap and some water.
Not waste OCW, just my lazy way to try save one step of detailing.
After claying just buff and all done :D
Hey..thanks for all the onfo. Has anyone seen any difference in shine by putting OCW on with a PC as apposed to wiping it on with a micro fiber towel?
Lineman
