Lake Country foam sticks ???
Bunky
Detailing Gnosis
Does anyone have these?
My question is how far will the foam end of the stick collapse before it will bottom on the wooden part. I want a foam stick that has at least 5 to 6mm travel (almost 1/4-in).
The typical craft type stick usually has the stiffener almost to the end.
I can't answer your question but I'm courious too. I need something to clean the grill on my truck and I need it to collapse some
What I have is a cowling that has grooved pockets. The best thing I have found so far is q-tips or the flat paint sponges (craft type) but easy to dab into many many pockets.
It extends a little bit less than 1/2 inch past the stick. It also feels like there is a little rubber BB or pellet on the tip.
Can't wait to try these out! I think these would be perfect for certain grille cleansing. In fact I just worked on a MB C300 recently and would loved to have had something like this. If you pick these up Al, please give us a solid review.
Todd, do you know if the wheel woolies are coming over too? I've been wanting to try those out as well.
I just been using Q-Tips lately because of the different size lug nut holes out there. A few time I have to use some S100 Motorcycle Detailing Swabs.
I myself would like to try out the wheel woolies I do alot of Borani wires.
That would have been nice to use on a Bentley Continental GT that I worked on last November. That grill was a PITA!
Truth! I used the small Wheel Woolies with Optimum Metal Polish on this Flying Spur's grill. It was definitely time consuming but worth the results.
Those look very cool hows the hold up on them? I would say b/c it is lake country they are top notch quality!
