Klasses all in one as sealant
surfninjab
I am confused as to what this product is and does. Autopia care care.com reccomends it as a paint sealant. It says it does much more but not much about being a sealant.
I am curious if this is a good product to use after washing, claying, and polishing, but before waxing? Does it seal and protect your car?
KAIO is a chemical paint cleaner, that also leaves an acrylic sealant behind once wiped off.
So it is great in your process because it will clean your paint before you use a sealant or wax. The sealant base it leaves behind simply adds a little extra protection.
It does seal and protect but the protection is limited. It is usually only a few weeks. Around 3 for me.
Here is some information for the OP. The AIO is just that a AIO product that should be follow up with another product.
Always wash and dry your vehicle first in a shaded area. Always check for any type of contamination by placing your hand in a plastic baggie and gently run you hand over the surface and if you feel something like sandpaper or pebbles then consider to clay bar your surface first. Also do any type of paint correction bfore using klasse. Once your done prepping the paint then you can start with your Klasse process.
Klasse is a High Gloss Sealant and should be treat as that. Apply with a applicator pad ( should be damp from a QD ) and apply a small amount like a nickel size to your pad and apply with large oval motions with a little pressure and make sure to apply it THIN! This nickel amount on the pad should do around half a hood of a car. When your done in that area it should be almost no residue on the surface. But if there is a residue or heavy film on it then you apply too much. I recommend doing one panel at a time and wiping with microfiber towels and a QD. It should protection your ride for about 3 months before applying again all over.
Think of an AIO as an "all season tire" It works well in most instances, but doesn't do one thing really great.
