That much should suffice if your careful enough
(AIO) Application Methodology:
·First, and most importantly, thoroughly prepare your paint film surface.
·Wash, use detailers clay, polish and apply a pre-wax Cleaner
·Shake product container vigorously to ensure mixing
·Apply to a clean, dry surface away from direct sunlight
·Dampen the applicator with water or use a lubricating spray during application
·Place a small amount of product (about the size of a dime) on to a damp (but not wet) applicator (not the paint surface) apply a thin even film of product to paint surface.
·If you are using a Porter-Cable orbital polisher to apply AIO, use a mild cutting foam (white) pad, using a low speed (3.5 â€â€œ 4.0) and light pressure, let the polish / cleaners do the work
(SG) Application Methodology:
·Do not dampen the applicator with water or use any lubricating sprays during application.
·Apply to a clean, dry surface, with a temperature of >50 â€â€œ 90<o F, away from direct sunlight
·Place a small amount of product (about the size of a dime) on to a dry applicator (not the paint surface) and using a light to medium even pressure, apply a thin even film of product to paint surface.
·As an alternative, pour some SG into small misting spray bottle, this will enable you to cover the applicator while using the minimum amount of product, and this will ensure a super thin application.
·Apply to whole vehicle (3/4 to 1.0oz should be sufficient for most vehicles) taking care not to apply to absorbent surfaces (i.e. unpainted plastics and rubber trim)
JonM
