Klasse/Topper tips and question
jsoto
after checking out the pictures forum, I plan to use Klasse with P21S as a topper on my Black X5. I would love the durability of Zaino but I hate the reflectiveness that of Zaino on Black that I am seeing in the boards.
Couple of Questions
Is this the correct steps to follow
1 - Dawn
2- Clay
3- P21S Shampoo
4 - AIO
5 - SG
6 -AIO
7 - SG
8 - SIO
9 - SG
10 - P21S Wax
Since AIO is a cleaner, 2 months later, would it be possible to apply AIO to get rid of the P21S, and then top it off with P21S again.
Any dust issue with Klasse.
What QD do you guys use with Klasse.
1 - Dawn
2- Clay
3- P21S Shampoo
4 - AIO
5 - SG
6 -AIO
7 - SG
8 - SIO
9 - SG
10 - P21S Wax
You'll want to do it this way
1 - Dawn
2 - Clay
3 - Dawn
4 - AIO
5 - AIO
6 - SG
7 - SG
8 - SG
9 - P21S Wax
Between each layer, whether it be AIO or SG, how long is the recommended cure time. 1 hour or 1 day, etc.
AIO is a wipe it on, wipe it off product. SG needs to cure. Do a search on Klasse and you'll find more than enough good info to help you get great results with Klasse.:xyxthumbs
Just to save you a bit of time, don't alternate AIO and SG since AIO is also a cleaner and will strip previous layers of SG. I feel it's unnecessary, but if for some reason you want to strip all the P21S and re-wax you should just Dawn wash it. Follow HellrotCi's plan and if you have any swirls to remove insert that between step 2 and 3.
AIO has not cure time, SG arguably has a 24 hr cure but some have done multiple layers in 1 day. The search engine and some quality reading time will teach you everything you need to know. Good luck! :up
You need to allow the previous layer of SG to fully cure, or else you're just mixing the new layer of SG with the previous layer. Which is why 2 layers of SG spaced a day or two apart achieves better results than 4 layers of SG in one day (depends on climate of course).
