I have a 2007 charcoal gray Mustang. I just completed applying the second layer of Klasse SG after two coats of Klasse AIO. I applied the KSG in very thin layers and removing the haze was not a problem. What I have noticed is approximately 5 blemishes that are between 1/32 and 1/16th of an inch in diameter. I don't remember seeing the blemishes after the KAIO stage. The best way to describe the blemish is they are indentions that are are crater shaped. The only other place I have seen any thing similar is when using polyeurothane and had a bubble.
Has anyone seen anything similar or what was done to correct?
Thanks in advance!!
Thanks in advance!!
