How can you tell if SG is still present? I've applied three coats using the WOWO method, and the beading has decreased significantly in only three weeks. The SG was applied after AIO and a 24 hour period was allowed between coats.
I use Sonus Acrylic Spritz after washing. Does Sonus Acrylic Spritz contain alcohol, like some other QDs, and actually reduce the SG film thickness? Will Sonus Acrylic Glanz improve the SG life? If so, why would you use Sonus Acrylic Spritz instead of Sonus Acrylic Glanz.
