Klasse AIO question
qh187 said:
If I use 3m rubbing compound, will AIO be ok to followup? Or would I need a finer polish first?
Welcome to the site!! the AIO would be ok to follow but why are you using compound to start with?
Thanks! I'm using it to remove swirls. I have the Perfect It II already and I don't want to go buy other stuff unless I need to. I was under the impression that i would have some slight hazing after the compound. Would the AIO be able to fix that?
By hand or machine - AIO is a chemical cleaner so it will not reduce any hazing from the perfect it - BUT - perfect it is pretty mild I think so if you get no hazing then aio is just fine.
I've used the II plenty in-fact that was all that I used until I came to this site....I assume that you are going to use this by hand? so work in small areas...about 12x12 inch areas...this will help you to keep control over the product....heat really is the key and by hand the small more condensed area the better for this...As stated above the II is a mild compound so you should not see any hazing associated with most compounds.....follow up with the Klasse and you should have a good shine...I also would try this method on one part of your hood to just make sure that you are getting the results that you are looking for.....If not then there are allot of good products here threw the sponsors that will help greatly by hand or machine
