Kenotek issues in cool weather?
Desertnate
Active member
Has anyone encountered issues with Kenotek when using it in temps around 50*F?
Recently, I was able to squeeze in two late season car washes when the weather turned unseasonably warm. On both occasions the weather was in the mid-50`s. I use Kenotek as a drying aid and/or post wash water spot remover. In the warm Summer and Fall weather, the stuff was amazing. Spread easy, very little need to make a second pass with the MF towel to remove it, and looked amazing. However the last two uses in the same much cooler weather, it was a totally different story. The product sprayed like normal, but once on the paint it was a streaky mess that was somewhat hard to buff out.
Had the temps been much cooler I would have expected those results, but 50-ish really isn`t that cold. Have others experienced these issues? I`ve used Meguiars QD spray, Meguiars UQW and Sonus Spritz in similar temps with no issues, so I was a little surprised this time around.
Perhaps it did not like the cooler temp and the moisture ???
If there was a lot of extra moisture at the time..
Did you apply it exactly as you had before when it worked right ?
Dan F
Sorry for the delay, I was working all weekend.
Yes, I applied the same way and used the same amounts. I tried applying directly to the surface and sprayed it to the MF towel and then applied to the surface with similar results.
I`ll just scratch it up to temperature and humidity causing the problems.
Yes, I`ve noticed this...to the point when I stopped using it last winter (during the winter). I love the stuff, but I`ve switched to SiO2 products now to streamline. It still worked fine in the colder temperatures, but it required extra buffing to wipe away.
Thanks! Glad to know it`s not just me.
Which products are you using, Ech20? All of my cars are wearing coatings, so I`d be interested in a good QD spray that works in a wider range of temperatures.
There are many good products on the market today, but I can`t help but noticing many of those based in the US are in warmer climates. I think Prima is the only one I know of in a more Northerly area (Colorado). I`m sure they do significant amount of product testing, but it makes me wonder if any of it occurs in colder climates. Very few detailing products I`ve used work well below the mid 50`s F. Sure there is physics at play when temperatures drop, and I`m not looking for something to work below freezing; just something that`s still easy to use down to the mid/low 40`s F
Both Finish Kare #146 and Britemax Spray & Shine Antistatic quick detailers were harder to buff off and streaked a bit at similar temps, but i wouldn`t say they were difficult.
I haven`t used the pink Finish Kare #425 or Kenotek yet, but hopefully this weekend I will.
Sent from my SM-G955U using Tapatalk
