just got my swirl buster
superchargedg
Twin Turbos
i have a ?,i just got my swirl buster pad and polish.i think i messed up,i got the pad with a 6" backing plate.i tried it and it did not vibrate much at all with my 7424,but i tried it with the sonus blue pad and it shook like crazy.i just ordered the 5"plate,can i still use the 6" backing plate with the swirlbuster polish and the swirlbuster pad.will i have any problems at all.plus 1 more ? if i use nxt wax will it remove what i just tried to fix,or should i use something different.
thanks all.
The SB Pad works fine with both 6" and 5" backing plates. With a 6" backing plate it is a little more agressive. This is the setup I like the most.
db
sorry dave,but i have 1 last ? before i jump in tomorrow.you say to load up the swirl buster pad ,does that mean fill up 2 rings and go at it for the 1st 2x2 section.after that for the next section should i do the same....cause that seems like a awful lot of polish.
thanks bud.....i cant wait to see the results.
I basically put two rings of polish into the grooves. It is a lot of polish, but it covers a pretty good size area. When I do my Cayenne I use about 4 ounces (maybe a little less).
Remember to spray the pad with a couple shots of detail spray (before you load the pad) to keep the pad moist.
