wifehatescar
My L5-S1 is killing me!
Hopefully this forum is ok for this post...
I've been trying to decide the quickest way to either:
A. jack up the front of the car and put it on jackstands to change tires
or
B. jack up one side of the car as if to rotate tires.
I have jacked up the car under the tranny/motor or suspension areas before but I've heard it's not good for the motor mounts. On my FWD car, the only place I feel safe putting a floor jack under is the 4 pinch welds behind the front tires and in front of the rear tires (the factory recommended spots). However, if I use a floor jack on that 4" area of the car, there is no way to then use a jackstand (there's only space for one or the other).
My latest brilliant idea is to use no floor jack and no jackstands. I would buy 2 scissor jacks (like for spare tire use supplied by the factory) with hex drives on the threaded part. Then I would place one under each recommended pinch weld and jack it up using my air impact gun
I figure I could safely jack up the side or front of the car safely like this in under a minute. This would be just to change tires, etc--- not to get under the car.
Thoughts/opinions/suggestions???
or
