It is 37 degrees outside can I wax in my garage? URGENT
I have used s100 in the same temps and it was fine. SG was a bit tricky but if you do the woo method it should work fine.
In a garage without the wind blowing on it you should be fine putting another coat of UPP on it too.
I waxed my car once a month all winter last year, which means I was waxing on days when it was below freezing. Everything worked out fine...the wax hazed over and I buffed it off without any problems. The finish was slicker afterward and repelled water better than before so obviously the wax bonded fine.
Go ahead and wax.
Are you using UPP over SG?
I actually put some AIO and SG on my mom's car the other day after washing and claying it. The afternoon started around 45F, and after the sun went down it was probably between 35-40F. Everything went fine for me, so go for it. I'm hopefully putting another layer of SG on my car tomorrow after a good wash :)
I put a coat of SG on over 2x UPP. Worked out fine, couple of spots where it got tough getting it off but I appled a little QD and it was fine.
For those that are concerned yes you can put SG on UPP without bonding issues.
White95Max: Did you wax outside or in the garage. I would like to get a coat or two more of SG when the weather allows but with 2UPP and one SG I think it will be fine. I will prolly do another tomorrow but then we are looking at snow. Ugh winter is here. I want to be back in Atlanta!
DetailGirl said:
Scottwax a true gentleman even if he is a Bush supporter :p ;)
No, I am not gentleman, I just don't want to get banned. :p
Besides, you ought to know by some of my posts on OT what a perv I really am. :lol
