imported_Detailing Technology
I use a 50/50 mix when removing polish residue, but does anyone use it to remove wax residue or to correct non-dried wax smearing?
jsatek said:I thought it would either weaken or remove the new wax.
BlackElantraGT said:I've always been curious about the dilution ratio for the 50/50 mix of Isopropyl Alcohol and water.
If the rubbing alcohol is only 70% isopropyl alcohol and the mixture is asking for 50/50, if one were to make a 10 oz solution of the 50/50 mix, are you guys diluting it 5 oz water with 5 oz of 70% isopropyl alcohol? Or would the ratio be different since the rubbing alcohol is diluted to begin with?
