is a glaze necessary for an ultimate shine?
Dairyman
i have used IP and FPII on a couple of cars the results have been pretty good but when i used to simply use a standard machine glaze with a medium cut pad it would hide the swirls and give such depth and shine to the paint better than the menzerna... maybe i need to get more experience iwth the menzerna polishes the two cars i ahve used them on so far have had extensive swirls though...?
Why not use menz first and then use a soft pad with the glaze.
I never finish with menzerna, not FF or RD
For a killer finish, I like to go to 4000 grit polishes and abrasive free glazes
I wouldn't switch to the FPII until you'd already removed anything too serious for the glaze to fill. I don't use much Menzerna stuff (and I've never used IP) but I let the heavy/medium cut products get rid of the marring before I switch to the fine products/pads.
Depth and shine are one thing, and a glaze might be just what you need on a given paint. But when it comes to marring I'd expect to polish it out and not need the glaze (for *that* purpose). The best finishes I've ever attained were done without a glaze (good thing, as I used sealants on them) but that doesn't mean they wouldn't have looked "better" if I put a glaze on the marring-free paint the way SVR does.
where are 4000 grit polishes available?
I get mine from a mob called car toys in adelaide
Ultra gloss superfine polish. It's so mild but gets the paint (especially single stage reds) looking magnificent.
Accumulator : How come you haven't used much Menz?
IP PO91L is a fantastic 1500 grit compound/polish which only letdown is alot of dust (I cut that down with my quick shot spray after the initial pass on the buff.
Even by hand their range is excellent.
glazes arent completely necessary. as stated above, great looking finishes can be had with good polishing and then a nice topper. I personally use glazes alot though. granted the concealing abilities of the glaze only last a short while (few weeks or so), but with reapplication, it looks great again. i've always taken the mindset of hiding instead of removing. i figure, i can glaze until my heart is content, while i can only polish so much before the clear is compromised.
My favorite painter swears by Menzerna, so it's not like I'm against it or anything. If I were starting from scratch I'd probably go with Menzerna and a few things from Hi-Temp.
I've been able to get the finish I was after with the (old) stuff I've always used. I have some of the BF/Menzerna SRC Finishing Polish I want to try some time, we'll see how I like it.
When I used FP I just didn't like the finish it left (on already-marring-free Audi clear) as well as 1Z Pro MP :nixweiss And I have gallons of my old faves PI-III RC and MG for the regular correction so I've never felt the need to try stuff like IP.
use IP twice, then FPII twice, then do half the car with a glaze to see if there is a difference...if there is continue, if not, IPA wipedown and seal it up!
I always glaze. I tried FK1 glaze (which actually has some cut to it!) and this year I am going to try Menzerna Finishing Touch Glaze. My usual go to glaze is surprisingly Mothers Sealer & Glaze, I don't know why but I love this stuff! A coat or two of it followed by IW845 and topped with AW has never done me wrong on most cars, but I like to test & tinker with new combos on my car :D
