I notice a lot of people recommend using IPA as a 50/50 solution with water. Is there something wrong with just using straight 70% or 91% IPA? I'd think if it doesn't hurt, it probably cleans better at full strength. So any reason to dilute it?
Also, the water in the solution will probably evaporate clean, but if you mix it you'll have to use distilled to do the same or you'll possibly leave something behind right? So this is another reason I see to not mix.
Also, do you guys rub the IPA in like you're really trying to clean the paint of stuff though you can't see it. Or is it just a light pass and it'll do it's job?
