Instant Detailer contains wax?
Bear
I bought the 5030 kit and have read that if you wax over sealant it will have to be removed in order to apply more sealant at a later date. I may not use the wax due to this but the instant detailer contains wax so that means I can`t use it either? If this is the case it makes over half of the kit useless. Will Zaino detailer be safe over Blackfire Sealant? It stinks that I can`t use Blackfire`s Instant Detailer.
the "wax" protection from the detailer spray will be gone in a wash or two, so when you think it`s time to re-apply sealant as your base layer, I would just go ahead.
Example: Blackfire Sealant base layer. Midnight sun or other carnauba wax over sealant, and some detailer spray after wash as a drying aid. You would roughly wax every month or so, while the sealant would last for say 4 months. At the end of the 4 months, just re-apply sealant after waiting the month after applying last coat of paste wax.
As Ron said, we are way overthinking this. :)
Nick
Excellent question, Bear. Nice response, clark08. I never realized the fact that topping with a carnauba can then be added Sealant again later as long as the carnauba application has worn off.
