mjlinane
My name is Mike
Initial Impressions: Gtechniq T1 Tyre and Trim
Introduction:
A new product line added to the ACC fold gave me all of the excuse I needed (which, admittedly, isn't much) to buy and try.
Thanks again to Corey for providing the format.
Product
Product Claims:
From Autopia Car Care site - Gtechniq T1 Tire & Trim 250 ml.
"Take control over your tires gloss and look!
One coat provides a satin finish
Two coats provides a high-gloss finish
Excellent durability and protection.
Gtechniq T1 Tire and Trim is a long-lasting tire and trim dressing that gives you ultimate control of the final look. Gtechniq T1 Tire and Trim is based on nanotechnology for extreme durability, water repellency, and oil repellency. Your tires and trim will look better for longer. This tire dressing is Smart Surface Science for your exterior rubber pieces.
Gtechniq T1 Tire and Trim is easy-to-apply. Thoroughly clean and dry tires first. Apply T1 Tire and Trim directly to a foam applicator and spread evenly onto tire and/or trim. Remove any excess product with a separate cloth. One coat will provide a satin sheen. If you desire a gloss finish, wait ten minutes and repeat the application steps.
Once your tires and trim pieces are protected with Gtechniq T1 Tire and Trim you will notice they stay cleaner for longer. This is because Gtechniq T1 Tire and Trim has been specially formulated to resist moisture and oil. The deep, dark look will not sling onto bodywork or wash away at the first sign of rain. Do not use Gtechniq T1 Tire and Trim on motorcycle or bicycle tires."
Details:
1.- Packaging: Plastic bottle
2.- Directions: Clearly labeled
3.- Viscosity: Oily
4.- Color: Translucent
5.- Scent: Chemical
6.- Price at time of review: 250ml = $ 16.99
7.- Manufacturer: Gtechniq
9.- Made in: British company anyway.
Other Products Used:
Sponge Applicator
Carrand Brush Applicator
MF
Preparation:
Cleaned tires with Zep Citrus Degreaser (4:1) & brush. Dried with MetroVac Sidekick and MF.
Application:
Shake well. Apply to sponge applicator and spread on tires. I followed with a second coat 10 min later using Carrand Brush applicator. Wiped off excess with MF.
Observations:
Light chemical smell. Not as easy to spread as Carpro PERL or BF Total Eclipse and excess is not easy to remove excess if you have ribs on the tires. Dramatically darkens tire. Leaves a pretty glossy finish.
Does it meet its claims? In general.
Pros:
1.- Rather easy application and removal
2.- Darkens tires
3.- Glossy finish.
1.- Durability - We'll see.
Cons:
1.- None.
Final Observations and Summary:
I definitely liked how Gtechniq T1 darkened the tires. Would probably have liked 1 coat better (less glossy). Durability will be the overall deciding factor on just how much I like T1.
I will update.
Comments and questions are encouraged. Thanks for viewing!
Introduction:
Product
Product Claims:
Details:
3.- Viscosity: Oily
5.- Scent: Chemical
Sponge Applicator
MF
Preparation:
Application:
Observations:
Pros:
2.- Darkens tires
3.- Glossy finish.
Cons:
1.- None.
I will update.
