mjlinane
My name is Mike
Initial Impressions: Detailer's Pro Quick Detailer
Introduction:
This is my fourth review of products from the new Detailer's Pro Aerosol series and thought this one would fall into my wheelhouse. I collect (it seems) QDs and use frequently, albeit not for light cleaning. I prefer to use them as drying aids and to add a little pop after a maintenance wash. If I need to do a light clean beyond freshly made waterspots from my MetroVac, I use a waterless wash.
Thanks to Corey again for providing the format.
Product:
Product Claims:
From Autopia Car Care site - Detailer’s Quick Detailer
" A fast and easy way to restore that "just waxed" shine!
Aerosol application is fast and easy.
Bonds with waxes and sealants.
Can be used to remove light dust and fingerprints.
Detailer's Quick Detailer is a quick way to restore a just-waxed shine in minutes! If you don't have time for a traditional car wash but still want clean, shiny paint, Detailer's Quick Detailer is the answer you've been looking for. Featuring a high lubricity polymer formula, Detailer's Quick Detailer safely removes light dust and fingerprints without scratching your vehicle's finish.
As a car care enthusiast on the go, you're always searching for a quicker way to clean and shine your vehicle's finish. It's not always necessary to perform a traditional wash when your vehicle only has light dust, dirt and fingerprints. Instead of consuming water and performing a timely wash, use Detailer's Quick Detailer to restore a just-waxed shine in minutes.
Application is simple: Working one panel at a time, spray on Detailer's Quick Detailer and wipe it off using a clean, dry microfiber towel. As the towel becomes soiled, flip to a clean side. Buff off any remaining residue with the dry side of the microfiber towel. If the vehicle is moderately dirty, more than one application may be necessary. Follow up with Detailer's Quick Wax to add a layer of protection and to amp up the shine even further.
Don't struggle any longer to keep your vehicle looking new. Have a can of Detailer's Quick Detailer on hand and restore that just-waxed shine in minutes."
Details:
1.- Packaging: Aerosol can
2.- Directions: Clearly labeled
3.- Viscosity: Light foam
4.- Color: White
5.- Scent: Can't identify it but quite nice
6.- Price at time of review: 16oz = $ 12.99
7.- Manufacturer: DP
9.- Made in: USA
Other Products Used:
16x16 MF (2)
Preparation:
Used on both of my cars (2011 Hyundai Sonata + UPGP and 2003 Hyundai Tiburon + Reload). Both were thoroughly washed with Pinnacle XMT Gel Shampoo & Conditioner (old formula) and dried with my 8hp MetroVac Master Blaster. Tires were dressed with Surf City Beyond Black (for the insatiably curious).
Application:
Apply lightly to paint. Spread thinly. Buff gently.
Observations:
Awesome smell. Not sure exactly what it is but really liked it. Light and slightly sweet. Adds tons of straight-up gloss.
Wished I had more good things to say but I struggled with DP Quick Detailer. It was much harder to control than DP Trim Detailer or DP Quick Wax. I think this is related to its consistency. It is very similar to Sprayway Glass Cleaner which I can't use on glass without making a mess. Both products come out with great velocity and go everywhere. I used inside my garage with the doors open (10AM and was already hot and humid) and I had light foamy stuff floating down the panels. (I figured out to work downwind so it not to matter so much.) Then I had issues with wiping off/streaking/smearing, especially noticeable on the Carbon Blue Tiburon. Had to go over multiple times to get it mostly clear and resorted to UWW+ (on the Tiburon - after the below pics). The extra wiping certainly added time. Wasn't sure if I used too much (likely) or too little but couldn't get it right. Got best results from light sprays but that was hard to do. As soon as it registered spray was coming out, it was already too much. Had variable cleaning results, too. It pulled some brown residue off of the Sonata that I didn't know was there (good) but had trouble with some white stuff that got on the Tiburon while drying (not so much). Also felt a bit "grabby" on application but became moderately slick upon drying.
Once you do get it off, it looks pretty good.
Does it meet its claims? Hard to say.
Pros:
1.- Pleasant smell
2.- Very glossy
1.- Cleaning ability.
Cons:
1.- Hard to control
2.- A little streaky on darker colors
Final Observations and Summary:
After being completely delighted with the first three DP aerosol products (DP Quick Wax, DP Trim Detailer and DP Leather Cleaner & Conditioner), DP Quick Detailer was a bit of a let-down. I titled this "Initial Impressions" because I haven't given up on it yet. Will try again and maybe Stig can toss out a few pointers. The streaky comment sounds bad but it is probably no worse than Optimum Instant Detailer. The main difference is I can better control the amount of product used with a spray bottle. It also should be noted I am extremely picky.
As for looks, that is a personal choice. I prefer the "wetter" look and it, coupled with UPGP at least, seems to make my Sonata look a little bland (no snide remarks, please).
Comments and questions are encouraged. Thanks for viewing!
Introduction:
Product:
Product Claims:
Details:
4.- Color: White
9.- Made in: USA
16x16 MF (2)
Preparation:
Application:
Observations:
Pros:
1.- Pleasant smell
2.- Very glossy
Cons:
1.- Hard to control
