Has anybody heard about this stuff before?
It kicks cancoat`s arse with the application on paper at least. Its also highly layerable and doesn`t flash(apparently) quickly like cancoat.
"Another unique aspect of Lite is its curing, once the coating residue has been removed the vehicle can be moved, or used within 5 minutes! No more "store indoors for 12 hours" like with other coatings. But you may ask, how does that work? After all ceramic coatings need time to fully bond to the surface. Yes, there is no getting away from the fact that coatings need time. However in the case of Lite, we have infused 2 polymer elements that act as a sacrificial layer to the coating immediately from application. They make the surface hydrophobic right away and also reduce the chance of water spots. These polymers last until the vehicle`s first wash, which we recommend doing no earlier than 7 days from the initial application (the vehicle can get wet within the first 7 days but do not clean with detergents)."
"Layering can be done as many as 20 times with Synergy Lite, this may be desirable if you are trying to hide a deep imperfection that cannot be corrected by machine. To layer simply apply the first application then remove immediately, the second layer and so on should be left for 1-3 mins before removal. repeat this process until the defect has been completely filled."
