Improved Ironx....
Greg Gellas
I'm Greg :)
Anyone used the new formula yet? Hows the smell? Still as effective?
♣ Improved Iron Cut formulation, 2011-11-17
Ladies and gentlemen,
Because Iron Cut is very harmful formula treatments, we had to change it for our health.
New formula Iron Cut has no longer bad smell and cause stains make.
The water repellent effect is also improved.
Especially, as AQuartz Iron Cut has water-repellent effect, after rinsing Iron Cut, the remaining water-repellent effect helps in avoiding the formation of rust on the surface of brake rotors and body surface.
Because its liquid is bluish colour, you should be distinguishable from those of our rivals.
Beacuse previous Iron Cut was not for good health and has very bad smell, we had to change the formulation for a safe treatments.
After previous Iron Cut sprayed, it seemed a reaction time very fast purple clour to Iron fillings, but that wasn't exact correct.
Actually, it reacted purple colour to Air, Iron fillings and somethings like that.
Because it kepts on react to Air continuously, it happened to make a big damage on the car paint if we did not rinse it completely.
It made a the surface of brake rotors and body surface rust continuously.
So we had to strengthen the strength and made up for the weakness.
New formula Iron Cut reacts purple colour to Iron fillings only, if there are no Iron filling, no puple colour to change.
As it has a water-repellent effect, its reaction time is little slow than previous Iron Cut because it makes to prevent the water-absorb.
If you want to see its quick reaction, you should use a paint brush or a sponge after you spray it.
Please contact us to obtain the new Iron Cut improved and try to test it.
Thank you!.
