I can't seem to figure out how much product to apply and how to properly wipe and buff. For example, I washed my car over the weekend and on Monday noticed some water spots that I guess I missed (or they dripped from somewhere). In particular there were several spots on my hood (again, not sure how I missed them) in about a 1-2 foot area. Since it had been 2 days since I washed the car, and my garage gets very dusty, I chose to use Opti Clean to remove the spots. Again, since the car was a little dusty, I wanted to use enough product to ensure that I didn't cause any marring.
I used about 3 to 4 good spritzes in the 1-2 foot area to completely saturate the area. Using a very plush MF folded into 4 sections I gently wiped across with one side, flipped, wiped again, etc... However, either I'm wiping too gently or put on too much product, b/c no matter how many times I wiped the section, the car was still extremely wet. Do I need to wipe harder? Do I need a different MF (I'm using a good quality one from PakShak)?
Also, on a related note, if you are just cleaning up a small section like I was, how do you do it (or do you just do the entire panel instead of a small section)? Let's say the whole hood is a bit dusty, but I really only wanted to clean the section that had the spotting. If I spray the opti clean on just that section, and maybe a bit surrounding it, I'm eventually going to be wiping a dusty section with very little opti clean (the area around the area I'm trying to clean). Any suggestions on this would be great as well.
Thanks again!
Thanks again!
