Dear Customers,
It has come to our attention that a problem with the security of the E2K adapter to the 5/16 adapter may occur if the parts are not VERY TIGHTLY secured before buffing! The two adapters must be screwed onto eachother with alot of force in order to make sure that the violent vibration of the PC does not shake it off. In order to counter this issue we are highly reccomending the following remedy. Purchase the LocTite brand fastener product numbers 270 or 271 high strength thread locker adhesive and follow the directions. Place the product between the large 5/8 threads of the 5/16 adapter and the Edge2000 adapter. This will permenantly prevent the disengagment of the adapters. According to the manufacturer "is designed for the permanent locking and sealing of threaded fasteners. The product cures when confined in the absence of air between close fitting metal surfaces and prevents loosening and leakage from shock and vibration. Typical applications include the locking and sealing of large bolts and studs" In the near future we will be providing a single unit adapter with the 5/16 adapter already assembled, but for those who have already purchased the system we strongly suggest this Loctite method for added security in addition to secure hand tightening. If you have any questions or need to find your nearest LocTite distributor please contact us at the number below.
Thanks,
Aaron Krause (President & CEO)
777 Henderson Blvd.
Suites # 1 & 2
Folcroft, PA 19032
Æ’v Phone: (610) 583-4883
Æ’¢ Fax: (610) 583-4885
Æ’x Email: [email protected]
Website: www.edgepads.com
Thanks,
777 Henderson Blvd.
Suites # 1 & 2
Folcroft, PA 19032
